Hello!
Is the csv.export not finished with the last firmware version 2.1.17?
Product Versions - Com'X510
| Application version | 2.1.17 |
| MCU board FW version | 2.2.6 |
| Root Partition version | 4.1.9 |
| Soft Partition Version | 2.1.17 |
| Hardware version | 5 |
| GPRS modem version | SAGEMCOM Hi2C,A.005.03 |
| GPRS modem IMEI | 355278055954088 |
I have problems with the csv export and I have activated log and publish datas for:
1) Masterpact Micrologic E + IFE Gateway
2) Compact NSX + Micrologic E connected to IFM via IFE Gateway
3) PT100 - analog input
4) iEM200T - digital input
Export
Data export only for Nb. 1, 3, 4 with wrong data and date stamp, see below. The data from Dez.15/Jan16 datas can not published.
NSX Data export is not working and I have problems with the connections via IFM. See the attachment
CSV.Export - 11.01.2015 (Vienna) -> CSV.file shows only datas from Oct. 15 and the correct from Dez.15/Jan.16 can not exported.
| Gateway Name | Gateway SN | Gateway IP Address | Gateway MAC Address | Device Name | Device Local ID | Device Type ID | Device Type Name | Logging Interval | Historical Intervals |
| ComX510_Demo Case | DN15209SE000016 | 10.179.28.188 | 00:00:00:00:00:00 | iEM2000T - Demo case | 0 | 10000 | iEM2000T | 15 | 96 |
| Topic ID1 | |||||||||
| 1621 | |||||||||
| Error | UTC Offset (minutes) | Local Time Stamp | Active energy (Wh) | ||||||
| 19 | 60 | 10-28-2015 01:00:00 | N/A |
What is the problem?
Thanks for the help!!
Mfg
Andreas
Posted: 2016-01-11 06:30 AM
The issue most be manage by technical support team,
please could you send your request to au.technicalsupport@schneider-electric.com germany-tsc@de.schneider-electric.com
Best Regards
Lazaro
Best Regards
Lazaro
Posted: 2016-01-11 07:06 AM
Hi Andreas,
I'd love to know the answer to this, because I'm getting very similar descriptions of this issue from 2 other customers.
I haven't had a chance to grab any of the data logs / diag file, but the description of the problem is very similar.
Steven Yan
Hi Andreas,
regarding 1), 3) 4): you may want to double check the Com'X publishing setting format for the CSV file and try a different date format (DD/MM/YYYY versus MM/DD/YYYY).
regarding NSX connection / Export: does your breaker have no BSCM installed? we see similar behaviour when BSCM is missing although we do not understand why this should make a difference.
Regards
Bernhard
Hello Bernhard!
1) Export with TT-MM-YYYY was the solution and I am surprised that the export with NSX is now working.
2) The NSX is installed in the Smart Panel Demo Case without BSCM.
Thanks for your help.
Best regards
Andreas
