Gateways and Energy Servers
User | Count |
82 | |
46 | |
29 | |
28 |
we have a request to provide data from a Serial Modbus VarLogic in IEC61850 format.
Would you rather advise to use G3200? Did anyone already build the dedicated CID file?
Would you alternately recommend using an IEC 61850 capable meter (PM8000 or ION7650) to perform this?
Best regards
Hi Jean-Christophe,
This would fit into Gateways & Energy Servers that's why maybe nobody answered it.
Maybe G3200 would be good, but which Varlogic model, how many registers, what are the IEC61850 conversion requirements?
Not sure if anyone has built a CID file already, I didn't, but I am willing to help you.
Would you alternately recommend using an IEC 61850 capable meter (PM8000 or ION7650) to perform this? It's a very expensive approach vs G3200. Perhaps even after counting the engineering time.
Adrian
I have a similar requirement where PM2120 modbus data needs to be converted to IEC61850.Basic electrical parameters like voltage,current,power and energy values are required in IEC61850 format.
Can I use G3200?
Yes, Ed.1 only.
