Are there any limitations with 1.5 on back-up and restore on another PAS related to Zigbee Green power devices ?
Gateways and Energy Servers
Showing results forΒ
Did you mean:Β
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Are there any limitations with 1.5 on back-up and restore on another PAS related to Zigbee Green power devices ?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Guillaume_Evrard
Captain
Posted: β€Ž2022-11-29 05:51 AM
1602
I could not see any limitations in the release note, I thought we had a limitation....
Thanking in advance,
  • Commissioning
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: β€Ž2022-12-13 11:05 PM
Hello Guillaume,
Yes that is correct. The restore operation overwrites the address of the ZIgBee chips in the gateway and it is not possible to overwrite this value more than once.
So of course, it is possible to use a new Panel Server for one-time backup restore. Restoring a 2nd backup file to this Panel Server will not be possible.
this was already the case with PowerTag Link.
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Replies 4
Thierry_Baudard
Commander
Posted: β€Ž2022-11-30 10:04 AM
1572
Hello @Guillaume_Evrard
Guillaume,
I estimate you and I know that you are a relevant guy... but ii think that post riddle  is not the most efficient way to ask question and use this  forum !
Ask your question... if you want πŸ˜Š
Thierry BAUDARD
Guillaume_Evrard
Captain
Posted: β€Ž2022-11-30 10:40 PM
1551
Hello @Thierry_Baudard ,
Not sure to understand why ?
Kind Regards,
Guillaume_Evrard
Captain
Posted: β€Ž2022-12-07 06:21 AM
1433
I have identified the limitation. the RF-ID of the zigbee network is using the MAC address of the Zigbee radio.
If you want to restore the backup of a faulty PAS to a brand new PAS, you have to overwrite the MAC address. You can do it only once.
First restore :
If you try to restore another back-up from another PAS you are getting this.
Thierry_Baudard
Commander
Hello Guillaume,
Thierry BAUDARD
Β
