Acti9 SmartLink and SSL/Can2Go
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Acti9 SmartLink and SSL/Can2Go
Romain_Polette
Kirk Romain_Polette Kirk
107
Guillaume_Evrard
52
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
LaurentCoene
Captain LaurentCoene Captain
Captain
Posted: ‎2014-08-25 08:59 PM
I was asked by in Hong Kong how to control the devices on a SmartLink from SSL.
It's just a simple script away.
Here is for everyone just in case (obviously you could also read the status and update your BV value or you could simply use the pre made device and work with it):
modbusId = 9
channel = 10
registerId = 14200 + (channel-1)*40 + 2
if pg8_init == nil then
    pg8_init = true
    currentValue = scl.nodes["ME"]["BV12_Present_Value"].value
    modbus.close() -- First, close it (just in case it was left open).
    modbus.open(
        12,      -- CAN2GO Modbus ID
        "RTU",   -- ASCII or RTU
        9600,    -- BAUD RATE
        8,       -- Data Bytes
        "EVEN",  -- Parity mode
        1)       -- Stop bits
end
-- Write to Breaker
newValue = scl.nodes["ME"]["BV12_Present_Value"].value
if newValue ~= currentValue then
    print("Sending modbus request")
    result = modbus.hr_write(modbusId, registerId, newValue+1);
    print("Result: " .. result)
    currentValue = newValue
    print("Contactor change successful")
end
Tags (4)
  • acti9
  • can2go
  • smartlink
  • ssl
Replies 0
