Video: Install EcoStruxure IT Gateway on Linux
Gateway software installation and setup
Step-by step instructions for how to download, install, and set up the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway software installation and setup
  • Video: Install EcoStruxure IT Gateway on Linux
  • Mark as Read
  • Installing and setting up EcoStruxure IT Gateway
  • Video: Discover devices
  • Discovering Smart-UPS in the Gateway
  • Import a device list to discover devices in EcoStr...
  • Configuring cloud connectivity in the Gateway
  • Set up redundant EcoStruxure IT Gateways
  • Installing the EcoStruxure IT mobile app
  • Updating EcoStruxure IT Gateway to the latest vers...
  • How to replace your EcoStruxure IT Gateway with a ...
  • Installing EcoStruxure IT Gateway on CentOS no lon...
  • EcoStruxure IT Gateway installer checksums
  • Video: How to deploy EcoStruxure IT Gateway
  • Video: Install EcoStruxure IT Gateway on Windows
  • Video: How to discover Modbus devices in the Gatew...
EcoStruxure IT Support
Request Support
Back to Gateway software installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-25 12:26 PM
Last Updated: Sisko JLehr Sisko ‎2025-02-27 04:49 AM
EcoStruxure IT Gateway supports Red Hat Enterprise Linux 8 and 9 and Rocky Linux 8 and 9
RHEL 7 is not supported in Gateway versions 1.23 and newer.
For existing Gateway installations, deploy the current Gateway version on a supported Linux operating system. To retain sensor history, follow these instructions:
How to replace your EcoStruxure IT Gateway with a new installation
System requirements for EcoStruxure IT Gateway
IMPORTANT: The user running the Gateway installer must have file system privileges set to umask 0022 or 0002. Otherwise, the installer cannot initialize the database.
See more User permissions requirements in System requirements for EcoStruxure IT Gateway
Install the Gateway from the Linux terminal via SSH.
Installing using the Linux GUI is not supported; it will cause a crash and require a reboot.
  1. Download the EcoStruxure IT Gateway install package to the server. Navigate to the directory where the install package is located.  Type cd and then the directory, for example:
cd /tmp/EcoStruxureITGateway-<version>-linux-x64.run
  1. Give executable rights to the install package. Type:
chmod 755 EcoStruxureITGateway-<version>-linux-x64.run
  1. Install the EcoStruxure IT Gateway. Type:
./EcoStruxureITGateway-<version>-linux-x64.run
  1. Continue through the prompts to finish the install.
  2. Open a web browser and go to https://your_server_ipaddress/
    Enter a password for the
    admin user.
  3. Follow the prompts to configure settings and register the Gateway with EcoStruxure IT. For detailed instructions, see Installing and setting up EcoStruxure IT Gateway
  4. In EcoStruxure IT, go to Administration > Gateways. You can see the Gateway is now connected to your account.
100% helpful (1/1)
