Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Posted: 2021-03-17 10:58 PM
Wireless themostat is becoming popular in markets.
Do SE have this kind of function for thermostat?
Posted: 2021-03-17 11:33 PM
TH900 series thermostat can offer Zigbee 3.0 and Modbus communication.
This thermostat can support PTAC, Fan Coil, Heat Pump and Gas/Oil Furnace applications.
Posted: 2021-05-03 01:53 PM
Yes, the TH903-ZPM-W is a Zigbee & Modbus Thermostat.
You can find attached the datasheet.
Posted: 2021-05-05 03:48 PM
The SE8000 series with the wifi adapter work pretty good. Long range too.
Posted: 2022-02-11 06:12 AM
Hi @Kirk69 ,
The Honeywell T9 seems to be home heating solution that works with Alexa, Google Assistant etc.
Have you looked at the Wiser solution:
This is the UK version of the product, there may be a version for your region https://wiser.draytoncontrols.co.uk/
