Using an M580 as a FTP server to connect a feild device
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Using an M580 as a FTP server to connect a feild device
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Modicon M580
Back to Intelligent Devices Forum
RobHudson
RobHudson
Cadet
Posted: ‎2023-02-08 10:28 PM
3422
I have a Remote flow meter that I want to connect to an M580 PLC using FTP, I cant find a guide on how to do this?
The flowmeter needs the following, what values do I use?
Server URL
Port
Username
Password
Destination Path
  • Communicating Actuators and Energy Valves
  • Flow & BTU Meters
PV_DAQ
Ensign PV_DAQ
Ensign
Posted: ‎2023-02-13 05:12 PM
In response to RobHudson
Well, the last letter A in the model number 7ME68104HN313AA0 indicates that there is no optional communications module installed on that Mag8000 (a quick read of the manuals says that an IrDA port is needed to communicate with the proprietary Windows Flow Tool or PDM software needed for configuring the flow meter, so the IrDA port is probably standard)
Here's a list of the optional interfaces:
Here's a link to the manual:
https://support.industry.siemens.com/cs/document/109812685/sitrans-fm-mag-8000-battery-operated-wate...
Note that the battery life chart on page 75 for use without any comm interface: Modbus RTU over RS-485 is going to drain the battery substantially.
The data sheet on IIoT is filled with jargon that's way above my paygrade.
IIoT Wireless Communication Module & IIoT Web Application Product Sheet and Specific Terms
https://cache.industry.siemens.com/dl/files/300/109812300/att_1110202/v1/MAG_8000_IIoTWCMWA_Product_...
If you figure out what it means, I'm curious.
Replies 4
PV_DAQ
Ensign PV_DAQ
Ensign
Posted: ‎2023-02-10 11:17 PM
3397
I've done a lot of industrial communications but FTP is not a common industrial protocol.  What brand and model of flow meter uses FTP (and why)?  Usually FTP communications is implemented with a PC and its capabilities, particularly almost unlimited memory.
I'm guessing the flowmeter must have historical, recorded flow or total data that needs to be transferred as a block of data, which is something that Modbus does not do well, but which an FTP client could call.
RobHudson
RobHudson
Cadet
Posted: ‎2023-02-13 02:55 PM
In response to PV_DAQ
3371
Hi PV_DAQ,
I'm by no means fixed on using FTP, its just unclear how to get the data effectively onto SCADA without additional hardware. It is a Siemens SITRANS FM MAG 8000 (product code 7ME68104HN313AA0), its installed at a remote location (15km from site) and already has Assetminder Thingworx site working, on this webpage it has FTP forwarding built in. Is there a different way for getting this data to SCADA?
I would typically by using 4-20mA and for remote sites use wireless or radio repeater however, since this has IIoT builtin I'm exploring the option to avoid installing new hardware.
PV_DAQ
Ensign PV_DAQ
Ensign
RubyHowells
RubyHowells
Cadet
Posted: ‎2023-02-15 10:52 PM . Last Modified: ‎2023-02-15 10:53 PM
Thanks for information!
