SLASXC2 CO2 Sensor
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SLASXC2 CO2 Sensor
CraigEl
Administrator CraigEl Administrator
42
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
Joe_IE
Ensign Joe_IE Ensign
Ensign
Posted: ‎2022-06-29 07:05 AM
1968
SLASXC2 CO2 Sensor
We have been asked by a client what area range is covered by our SLASXC2 CO2 sensor.
There will be open plan areas of varying sizes and they want to calculate how many sensors are needed for each.
I cannot see this information in the datasheets
Joe
DavidChild
Sisko DavidChild Sisko
Sisko
Posted: ‎2022-07-05 06:09 AM . Last Modified: ‎2022-07-05 06:10 AM
Hi @Joe_IE ,
The sensor will only measure the air that is drawn into it, so will only measure the air in its own vicinity..
So, would be dependent upon air movement/air flow, how close the install is to the point being measured.
The install will need to be placing the sensor into the area that needs to be measured i.e. the occupied area, rather than doing an install in a diluted unoccupied area.
DavidChild
Sisko
Hi @Joe_IE ,
