PW2LX04BP alternative model in SE products.
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • PW2LX04BP alternative model in SE products.
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Rajakumar_K
Lt. Commander Rajakumar_K
Lt. Commander
Posted: ‎2022-09-19 12:51 AM
3064
Hi
In SE products, is there any alternative model for PW2LX04BP-Veris available with bypass mounted assembly option?
I knew EPW is the alternative model to PW2 series models but not sure whether EPW has a standard bypass mounted assemble option.
Regards
Rajakumar K
  • Pressure Sensors
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
Lieutenant JG
Posted: ‎2022-09-30 10:06 AM
2908
The AA14A (separate) and AA16A (installed on product) bypass assemblies are available.
For example: if the EPW and AA16A are on the same order they will be connected.
Otherwise they will be separate.
Take Care,
Troy
Replies 5
Troy_Wecker
Lieutenant JG
2909
Take Care,
Troy
Rajakumar_K
Lt. Commander
Posted: ‎2022-10-01 11:22 PM . Last Modified: ‎2022-10-01 11:22 PM
In response to Troy_Wecker
2870
Hi
Are these part numbers(AA14A & AA16A) from Schneider or Veris?
I am looking for bypass assemblies for EPW105 from Schneider products.
Regards
Rajakumar
Aaftab
Ensign Aaftab Ensign
Ensign
Posted: ‎2022-10-02 02:08 PM
In response to Rajakumar_K
Hi
The AA14 & AA16 part numbers can be ordered with Schneider Electric.
The EPW105 supports an operating range of 0 to 250 psig whereas PW2LX04S supports an operating range of 0 to 100 psig i.e. the Schneider Electric equivalent part number based on operating range is EPW104.
If you want to purchase EPW105 with bypass assembly, please order AA16 with EPW105 in one order with Schneider Electric so that it will be factory assembled and shipped.
If you want to purchase bypass assembly separately please order AA14 through Schneider Electric.
Hope it clears the ordering process.
Troy_Wecker
Lieutenant JG
Posted: ‎2022-10-05 09:41 AM
2807
The products are available in iPortal.  They fit both the Schneider and Veris products.
Troy
CraigEl
Posted: ‎2022-10-05 04:01 PM
and for the 95% of the world not in North America... https://www.se.com/ww/en/product-range/65612-pressure-sensors/73612493678-wet-pressure-transmitter/?...
