MP130-24M Actuators Always giving 10 Volt Feedback.
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • MP130-24M Actuators Always giving 10 Volt Feedback.
CraigEl
Administrator CraigEl Administrator
41
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
Nick_Ortlipp
Crewman Nick_Ortlipp Crewman
Crewman
Posted: ‎2019-09-15 09:07 PM . Last Modified: ‎2021-03-17 03:53 AM
4109
I have 10 + MP130-24M Actuators installed on a project. All are giving ten volt feed back no mater what the signal is. The feed back only modulates (10 volts- 0 Volts-10 -Volts) When the reset button is pushed. All cables and signals have been proven. I thought it may have been a faulty one at first but each successive actuator has the same issue. MP500 and MP300 installed all work perfectly.
Any ideas on a fix would be greatly appreciated.
  • Pressure Independent Valves and Actuators
  • MP130-24M
Simon_Firth
Lieutenant JG Simon_Firth Lieutenant JG
Lieutenant JG
Posted: ‎2019-09-27 10:54 AM
In response to DavidChild
1
4080
the MP130 actuator with feedback is the MP130-24MP
P for position feedback.
You need to first ensure the actuator is mounted on the valve, powered and calibrated. Output X is not correct until the actuator is calibrated.
You may need to reset the actuator for it to re-calibrate, and this reset is recommended if the manual override is ever operated.
There is a small push button on the PCBA next to the Dip-switches that re-sets the actuator.
Specification sheet attached
Mr Valve
Replies 4
Posted: ‎2019-09-26 07:21 AM
Hi the community members can you help this member on this topic please?
@WaynePeters or @DavidChild do you think you can advice on this topic?
@Nick_Ortlipp, in the meantime, please check the Knowledge base, maybe you can find useful information.
But if you still in the same situation please do not hesitate to inform us here.
Have a nice day.
DavidChild
Sisko DavidChild Sisko
Sisko
Posted: ‎2019-09-26 07:47 AM . Last Modified: ‎2019-09-26 07:48 AM
2
4088
Looking at the install sheet, these don't have feedback....unless I've missed something!
24Vac
Y = 0-10V or 0(4)-20mA control signal
Common
Simon_Firth
Lieutenant JG
1
4081
Mr Valve
Nick_Ortlipp
Crewman
Posted: ‎2019-09-29 04:49 PM
In response to Simon_Firth
Thanks for the feedback.
It looks like what the issue is, I was commissioning the plant before the chilled water was running. Once a pressure was in the pipes and a reset/power cycle was done on the actuator, the valves stroked and started giving the correct feedback.
I am a bit worried that with intermittent loss off chilled water pressure which happens often during the commissioning phases of construction, I may have to run around site and reset this model.
