Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Is it possible to disable TC900 FAN/Ventilation?
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Is it possible to disable TC900 FAN/Ventilation?
CraigEl
Administrator CraigEl Administrator
37
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
EcoStruxure™ Building Operation
Back to Intelligent Devices Forum
ld94
Lieutenant JG ld94
Lieutenant JG
Posted: ‎2023-03-13 02:20 AM . Last Modified: ‎2023-03-13 02:24 AM
1769
Good morning all,
my customer has the following request: when I have the start from an external thermostat the ventilation can be ON, otherwise it should be OFF (no low speed, completely off).
Is there a Modbus register that I can use to shut off the fan completely?
The only thing that came to my mind is to create an MTA that automatically matches the set point with the temperature read by the TC until the thermostat close the contact and set the register 16 "Fan operation after setting temperature is reached" to 0.
Any other solutions?
Thanks in advance,
LD
PatrickDumas
Captain PatrickDumas Captain
Captain
Posted: ‎2023-03-15 12:07 PM . Last Modified: ‎2023-03-15 12:13 PM
1717
I also think you have found the best and only option to ensure to turn the Fan Off (all speed) from a ModBus command.
- Setpoint = Room Temp
- Fan operation after setting temperature is reached = 0 (this may be left set to 0 depending on application)
- May also have to force Fan Mode = Auto (Register 5 = 03) ...conditional to Auto Fan = Enable.
Replies 5
CraigEl
Posted: ‎2023-03-14 05:28 PM
I'm not sure I 100% understand what is required but your idea does sound feasible.
Troy_Wecker
Lieutenant JG
Posted: ‎2023-03-15 10:45 AM
I will contact the Offer Manager for this product to answer this question.   Please standby.
PatrickDumas
Captain
1718
Troy_Wecker
Lieutenant JG
Posted: ‎2023-03-16 09:44 AM
See Patrick Dumas reply
ld94
Lieutenant JG ld94
Lieutenant JG
Posted: ‎2023-03-23 12:06 AM
In response to PatrickDumas
Thank you for the answer!
I'll try that.
Have a nice day.
This is a heading
