the difference between IEC 61000-3-12 and IEEE519
Expert on Demand for Standards & Regulations
Connect to Schneider Electric experts in your country for any inquiry about electrical installation and safety standards and regulations.
  • Power Distribution IEC
  • the difference between IEC 61000-3-12 and IEEE519
HelvinHermanT
Admiral HelvinHermanT Admiral
106
faisalamir
Lieutenant faisalamir Lieutenant
7
Dwinanto_Setyadi
Lieutenant JG Dwinanto_Setyadi Lieutenant JG
7
Back to Expert on Demand for Standards & Regulations
Widiyatmoko
Ensign Widiyatmoko
Ensign
Posted: ‎2022-02-24 01:12 AM
8470
Please share more on IEC 61000-3-12? And what is the difference between IEC 61000-3-12 and IEEE519?
Initially, I have the impression that IEC 61000-3-12 is observing a THDI of 5%.
@HelvinHermanT
  • Indonesia
Replies 6
HelvinHermanT
Admiral
Posted: ‎2022-02-24 10:25 PM
8455
Hi Pak,
The International Standard IEC 61000-3-12 has been prepared by subcommittee 77A: Low frequency phenomena, of IEC technical committee 77: Electromagnetic compatibility.
IEC 61000-3-12 Part 3-12: Limits – Limits for harmonic currents produced by equipment connected to public low-voltage systems with input current >16 A and ≤75 A per phase.
This part of IEC 61000 deals with the limitation of harmonic currents injected into the public supply system. The limits given in this International Standard are applicable to electrical and electronic equipment with a rated input current exceeding 16 A and up to and including 75 A per phase, intended to be connected to public low-voltage a.c. AC distribution systems of the
following types:
• nominal voltage up to 240 V, single-phase, two or three wires;
• nominal voltage up to 690 V, three-phase, three or four wires;
• nominal frequency 50 Hz or 60 Hz.
Other distribution systems are excluded. The limits given in this edition apply to equipment when connected to 230/400 V, 50 Hz systems
NOTE 1 The limits for the other systems will be added in a future edition of this standard.
NOTE 2 Equipment with a rated input current exceeding 75 A per phase should be considered in the harmonic current requirements for installations. See IEC/TR 61000-3-6 and future IEC/TR 61000-3-14.
This standard defines:
a) requirements and emission limits for equipment;
b) methods for type tests and simulations.
Tests according to this International Standard are type tests of complete pieces of equipment.
Conformity with this standard can also be determined by validated simulations
HelvinHermanT
Admiral
Posted: ‎2022-02-24 10:31 PM . Last Modified: ‎2022-02-24 10:35 PM
In response to HelvinHermanT
8452
The limits given apply to 230/400 V, 50 Hz systems. The limits for the other systems will be added in a future edition of this standard.
The harmonic current limits specified in the tables apply to each of the line currents and not to current in the neutral conductor.
The harmonic current limits are specified in Tables.
Please note that the data above is just for reference only. Please check the complete Standard for better understanding.
J_Travostino
Sisko J_Travostino Sisko
Sisko
Posted: ‎2022-02-28 05:59 AM
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
J_Travostino
Sisko
Posted: ‎2022-02-28 05:59 AM . Last Modified: ‎2025-08-11 04:13 AM
Hello @Widiyatmoko ,
I took the initiative to post your question into our Global Community:
"Power Distribution & Digital forum"
We got an answer from @DGonzalez to complement the discussion above.
I hope it will help.
You can check it out here. 👈 👈
Julien Travostino
Power Products Div.
sesa72599_bridg
sesa72599_bridg Cadet
Cadet
Posted: ‎2024-06-04 03:11 AM
4854
Hi
Thanks for the explanation. By any chance, do you have an IEC 6100 Electromagnetic Test Report for our USB charging units?
HelvinHermanT
Admiral
Posted: ‎2024-06-26 05:49 AM
In response to sesa72599_bridg
Hi, please contact your local Offer Marketing Manager. 🙏
