How to build Performance Scoring using EcoStruxure™ Building Operation?
Energy Efficiency and Sustainability Data Forum
Join our Community to support the Energy transition of Buildings, better monitoring their performance and providing an easy access to Green Certification.
Send InviteCancel
Posted: 2023-03-0906:42 AM. Last Modified: 2025-01-0706:03 AM
Are you looking for a way to easily perform analysis, generate reports, and calculate performance scores for buildings? Are you planning on (re-)certifying buildings on LEED V4.1 Operations and Maintenance certification?
Then you should take a look at this application note that provides an overview of Arc Performance program and explains how to integrate and interface Arc Performance scoring application with EcoStruxure™ Schneider Electric solutions deployed in a Building.
Arc Skoru Inc., a technology platform company affiliated with Green Business Certification Inc and the U.S. Green Buildings Council, has created Arc which allows buildings, city and community projects to collect data, manage and benchmark progress, measure impact and improve sustainability. Arc provides users with analytics across each performance category, as well as an overall performance score. Projects can use Arc scores to track and manage performance or achieve LEED certification.
Every sites with EcoStruxure™ solution can participate to the Arc Performance program. An API for interfacing Arc Platform with EcoStruxure™ solutions is available on Schneider Electric Exchange.
> Download below the Guide for performance score application using EcoStruxure™ building operation.
