SEAL 1.12.1.1 - WorkStation mismatch with server
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • SEAL 1.12.1.1 - WorkStation mismatch with server
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Thronborg
Lieutenant JG Thronborg Lieutenant JG
Lieutenant JG
Posted: ‎2025-02-03 06:40 AM . Last Modified: ‎2025-02-03 07:00 AM
1
726
I get the warning when I log in to my server through SEAL, which is the first thing I do after I opened the SEAL app. What i've been told is that the client should be the same or later release than the server. But this warning tells me the opposite.
What can go wrong if I proceed?
Install WorkStation v6.0.3 seems out of the question since it is deprecated at ecoxpert.se.com.
  • Issue
Benji
Posted: ‎2025-02-03 01:52 PM
Thanks @Thronborg - I've added bug 18101 to out system. I've reviewed the code, and the message is only informational. You can in other words disregard it in this case, but it would of course be best if the message only showed if WorkStation was 6.0.3 and server was 6.0.4, and not the other way around.
Thanks again.
Benji
Thanks again.
