Object Binder - SEAL Script
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Object Binder - SEAL Script
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2025-08-21 06:58 AM . Last Modified: ‎2025-08-21 07:04 AM
The Concept
The Object Binder Script simplifies binding objects in EcoStruxure Building Operation using a CSV file. It has two modes: Generate Binding CSV creates a template for defining bindings, and Make Bindings from CSV applies bindings from an edited CSV. Ideal for bulk binding tasks, such as linking multiple object properties across folders.
Key Features
  • Generate Binding CSV Mode:
    • Creates a CSV template listing target and source object paths from Workstation Search.
    • Editable in Excel, showing existing bindings and object details.
  • Make Bindings from CSV Mode:
    • Edit the CSV in Excel to define/adjust bindings.
    • Script Reads the CSV, using Target Property Path and Bind From columns to create bindings.
    • Processes only specified columns for precise binding.
  • Flexible Options:
    • Supports semicolon (;) or comma (,) as list separators.
    • Uses Workstation Search paths for easy input.
How It Works
  1. Generate Binding CSV:
    • Uses Search results made in Workstation as target (to bind to) and as source (to bind from) object paths.
    • Generates a CSV template with columns like Target Property Path, Bind From, and more.
  2. Make Bindings from CSV:
    • Reads the edited CSV, applying bindings from Bind From to Target Property Path.
    • Saves changes to the system.
Example Use Case
To bind Value properties of 10 objects in /Server 1/BINDING EXAMPLE/VALUES 1 (e.g., Analog Value 1/Value) to corresponding objects in /Server 1/BINDING EXAMPLE/VALUES 2:
  1. Generate CSV:
    • In Workstation, search for objects in VALUES 2 and copy search result to Target Objects to Bind.
    • In Workstation, search for objects in VALUES 1 and copy search result to Source Objects to Copy Bindings From.
    • Select Generate Binding CSV, choose an output file, and run to create a CSV template.
    • The CSV lists the objects like:
  2. Edit CSV:
    • Open in Excel, copy Source Property Path (e.g., /AS_P_6.0.3.112/BINDING EXAMPLE/VALUES 1/Analog Value 1/Value) to Bind From for each row, and save (ensure it is in UTF-8 CSV format)
    • Trim to Target Property Path and Bind From columns. (Optional)
  3. Make Bindings:
    • Select Make Bindings from CSV, choose the edited CSV, and run to bind VALUES 1 to VALUES 2.
Reuse: Edit the CSV (e.g., search-replace to bind VALUES 3 to VALUES 4) and rerun in Make Bindings mode.
The Script is available from SEAL Script, Standard Scripts
  • Script
Replies 0
