No valid License error EBOWS
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • No valid License error EBOWS
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
18
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-09-26 06:53 AM
341
Hello everyone,
I wanted to add the Spacelogic AS-B-24-P to the BOWS software and I encountered the following error: “No valid license to add the AS under the ES found” (screenshot attached). I tried to access the Spacelogic AS-B-24-P via the web interface and got the same error: ‘No valid client license available’ (screenshot attached).
All licenses are installed and activated (screenshot attached).
I need your help, please.
  • Design
  • Script
  • Training
dferter
dferter
Cadet
Posted: ‎2025-10-20 05:30 AM
@ElvisOla wrote:
Hello everyone,
Try refreshing the license in the License Administrator, make sure the AS-B-24-P is registered under the right ES, and verify that the entitlement ID matches. A restart of both the ES and AS often resolves the issue after syncing the license data.
