New type of binding script
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • New type of binding script
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
19
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
KevinC.232
Lieutenant | EcoXpert Master KevinC.232 Lieutenant | EcoXpert Master
Posted: ‎2025-05-29 02:08 PM
829
Hello, I was looking at the binding scripts as I thought they would be able to help my team with our Continuum conversions. The spreadsheet binder does seem to work, but in our case, it feels like it could be more convenient. Although, as this is new to me, it may not be possible.
Essentially, what I would like to do is take
/StLukes/Infinet Interface/Infinet Network A/Boilers/Application/IntrLkHeating/Value
and place it into any program bind with a certain input, making the "to" be like
* is wildcard
/*/*/*/*/*/xxxProgram/InputBind
Kevin C
  • Binding
  • Help
  • Script
StefanLundin
Commander
Posted: ‎2025-05-30 03:38 AM . Last Modified: ‎2025-05-30 03:40 AM
2
798
Hi Kevin,
I’ve made an adjustment to the Spreadsheet Binder to support using a wildcard(*) in the "To" path.
Note that this is a quick implementation that crawls the system to find the matching objects. While it’s not the most efficient method, I ran a quick test and it worked in my test environment —though it may take some time to complete the crawl on a large system.
Please test it and let me know if it meets your needs and perhaps we could add the support for wildcard in the official SpreadsheetBinder script later on.
Be sure to test it in an virtual environment and ensure you have a full system backup beforehand.
Example CSV file:
From;To
/Server 1/Common Signals/Digital Value/Value;*/Program/MyProgram/MyBindToProperty
This created the following bindings in my simple test :
[Log] Binding using 1 entries
[Log] Searching for properties ending with Program/MyProgram/MyBindToProperty
[Log] Found 6 properties matching */Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App1/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App1/Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App2/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App2/Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App3/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App3/Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App4/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App4/Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App5/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App5/Program/MyProgram/MyBindToProperty
[Log] Binding /Server 1/Common Signals/Digital Value/Value to /Server 1/App6/Program/MyProgram/MyBindToProperty
[Log] Successfully bound /Server 1/Common Signals/Digital Value/Value to /Server 1/App6/Program/MyProgram/MyBindToProperty
[Log] End
And if watched in EBO :
  1. Unzip the attached file
  2. Import to the script in the SEAL Script utility using the Import Script button
  3. Find the Script in your Custom folder and test it.
SpreadsheetBinder with WildcardSupport-1.6.0.zip
StefanLundin
Commander
2
799
Hi Kevin,
Example CSV file:
From;To
[Log] End
KevinC.232
Posted: ‎2025-06-03 08:38 AM
In response to StefanLundin
675
Thank you Stefan!
arlena
Lieutenant | EcoXpert Master arlena Lieutenant | EcoXpert Master
Posted: ‎2025-07-22 02:33 PM
In response to KevinC.232
Good work guys!
