I'm not able access to run SEAL tool
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • I'm not able access to run SEAL tool
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
19
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Anawat
Lt. Commander Anawat
Lt. Commander
Posted: ‎2025-06-09 07:38 PM
1111
I get a message access denied after install and run this SEAL tool first time. Anyone please guide me how can do to get permission to access.
Access denied
Your account does not have access to run this client.
  • SEAL
StefanLundin
Commander
Posted: ‎2025-06-09 10:44 PM
1097
Hi Anawat,
We've recently migrated SEAL to a fully automated solution, where access is automatically provided to users based on their partner status. All EcoXpert's being Registered, Certified or Master automatically gets access.
If you're an EcoXpert and unable to access the system, it's most likely due to an issue with the status on your Schneider account. Please contact your Schneider Electric account manager to review and update your information.
Once your account details are correctly updated, access to SEAL will be granted automatically
Replies 9
StefanLundin
Commander
1098
Hi Anawat,
Eli
Admiral Eli Admiral
Admiral
Posted: ‎2025-06-10 02:22 AM
Hi @StefanLundin ,
Not a question for me personally, but is there a way for EcoXpert's to see that status you're talking about?
Eli
StefanLundin
Commander
Posted: ‎2025-06-10 02:48 AM
Hi @Eli
Sorry but no - we actually don’t know if EcoXperts can view their own status somewhere in the system. Since we’re not involved in the account management as such, we don’t have visibility into that part.
Best would be to check with an account manager.
Burkal
Ensign Burkal
Ensign
Posted: ‎2025-06-10 10:07 PM
Hi
You can view it on your MySchneider under programs.
Anawat
Lt. Commander
Posted: ‎2025-06-16 08:03 PM
It’s look like my company incorrect on mySchneider account. I’m try contact local support to change it.
arlena
Lieutenant | EcoXpert Master arlena Lieutenant | EcoXpert Master
Posted: ‎2025-07-25 07:18 AM . Last Modified: ‎2025-07-25 08:56 AM
In response to StefanLundin
818
@StefanLundin
Stefan,
We are a Master level partner, and it seems to be "hit or miss" on whether our programmers have access to this tool.
The name of our company is Paape Companies based in Minnesota.
Specifically,
jgarland@paape.com
bradyh@paape.com
jonash@paape.com
jamesm@paape.com
shaunb@paape.com
thayned@paape.com
pranayt@paape.com
Would all like access.  Is this something you can do?  Or can you direct me to the proper place to make this happen?
Thanks!
Benji
Posted: ‎2025-07-28 10:26 AM
In response to arlena
771
Hi @arlena - there's various reasons, but all leads back to data. While it's a big upside that we realy 100% on automated processes and the backend data, it also means it breaks when data is not correct.
To take the two first contacts here as example:
jgarland@paape.com - this user does not seem to have ever logged in to e.g. mySchneider and linked their profile with the Paape Energy Services company. That basically means the user is unknown. The first time the user tries to log in, the user should make sure their profile is set up correctly with e.g. mySchneider.
bradyh@paape.com - this user does exist, but is not linked to the main Paape company, but rather a Paape account created in error (I assume). There is only 4 users linked to this account.
For accounts which are incorrectly linked, they need to get with you Schneider Electric representative.
jamesm@paape.com - I checked this account, and it actually seems to be registered and set up correctly. Has this user tried to log in?
arlena
Posted: ‎2025-07-28 01:29 PM
In response to Benji
769
Benji,
Thank you for the help.  You mentioned that there were 4 people linked to a different Paape account. Can you tell me what 4 people they are, and I will get our rep on it.
I'm thinking at this point, only those 4 people are the problem now.
I think they are:
jonash@paape.com
pranayt@paape.com
bradyh@paape.com
mikeb@paape.com
Thanks Again!
Benji
Posted: ‎2025-07-28 01:46 PM
I've sent you a DM - I can see it's actually 2 accounts, with 4 contacts on one, and 5 contacts on the other.
But yes, it seems related to that.
