Issue with tag in Text
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Issue with tag in Text
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
MikaelBodereau
Lieutenant MikaelBodereau Lieutenant
Lieutenant
Posted: ‎2025-03-24 03:54 AM
442
Hi Seal Design team,
I need to put text inside a Text Component without any replacement.
In my case i have many lines with this text inside entire text "  <16> ".
There is no issue to create file but text is not present and i have this error information :
Is there a solution to have raw text inside a text Component?
KR,
Mikael.
  • Design
StefanLundin
Commander
Posted: ‎2025-03-24 04:45 AM . Last Modified: ‎2025-03-24 04:46 AM
Issue is confirmed and I've created a bug to address this ( internal reference #18466 )
As a workaround you can divide the tag into two text parts
StefanLundin
Commander
