Installed Base Capture - SEAL Script
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Installed Base Capture - SEAL Script
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2025-10-26 06:03 AM
Purpose
The Installed Base Capture script collects device information from a connected EBO server (AS, ES, or EC). It supports system audits, inventory tracking, and upgrade planning by extracting structured data from various device types.
What the Script Does
When run on an EC, ES, or AS, the script automatically scans the entire server tree and captures data from the following device types:
  • EC, ES, Automation Server
  • Central IO
  • IP Controllers (MP/RP)
  • MSTP Controllers (MP/RP)
  • IP-IO
  • RPC RoomBus Devices
  • TAC Xenta
  • TAC Xenta IO
  • TAC Xenta IO in Xenta
Captured data includes:
Name ; Path ; Parent ; SKU ; ModelName ; SerialNumber ; Version
This information is written to the Results View and/or a CSV file.
Typical Use Cases
  • Installed base documentation for upgrade planning
  • Inventory capture for maintenance or lifecycle analysis
  • System audits and compliance reporting
Technical Notes – Why Set/Change Permission Is Enabled
Although the script only reads data, it needs to temporarily disable Database Mode (SetDatabaseMode(false)) to access live properties such as firmware versions from BACnet controllers.
Changing database mode is considered a write-level operation in EBO, which is why set/change permission is required.
Note on EBO Version Requirement
The script requires the top-level server (i.e. the EC or ES you connect to and run the script on) to be running EBO version 4.0.3 or higher.
However, underlying Automation Servers (AS) do not need to meet this version requirement. The script can still successfully collect data from AS and their connected devices even if they are running older versions.
Safety First
Make sure you have approval from the system owner before exporting system information.
Availability
The script is available in SEAL Script → Standard Scripts.
  • Script
Replies 0
