This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2024-12-04 10:31 AM
Hello, I'm sad to hear that you're experiencing this issue.
The error you're encountering indicates that Design is unable to compile a fully functional application program. This could be due to the specific combination of options you've selected not being commonly used or fully supported. Without analyzing your solution file, it's difficult to pinpoint the exact cause.
When you receive such an error message, there's unfortunately not much you can do on your own, except perhaps to deselect or change the configuration options you've chosen.
However, if you send your solution file through the support channel, we might be able to push a quick update to resolve the specific issue you encountered.
