CSV to Properties - SEAL Script
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • CSV to Properties - SEAL Script
StefanLundin
Commander StefanLundin Commander
33
Benji
Administrator Benji Administrator
16
Jim.T
Ensign Jim.T Ensign
4
APA
Lieutenant APA Lieutenant
3
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2025-08-21 02:28 AM . Last Modified: ‎2025-08-21 02:30 AM
The Concept
The CSV to Properties Script automates object property management in EcoStruxure Building Operation using CSV files. It supports two modes: CSV to Properties updates object properties from a CSV, and Properties to CSV exports properties from Workstation Search paths to a CSV. Perfect for bulk updates or documentation.
Key Features
  • CSV to Properties Mode:
    • Sets properties and bindings from a CSV file.
    • Optionally creates new objects if they don’t exist.
  • Properties to CSV Mode:
    • Exports object type, name, properties, and bindings to a CSV.
    • Uses Workstation Search paths as input.
  • Flexible Options:
    • Supports semicolon (;) or comma (,) list separators of the CSV
    • Option to run in Live or Database mode.
  • Error Handling:
    • Logs errors for invalid paths or files.
    • Saves changes incrementally for stability.
How to Use
    • Use Workstation search to do the selection for what objects you want to get properties for:
      Example : All object on the whole server with names ending with '_PB'
    • Copy the Search Result and paste this to the SEAL Script "Paste object paths from search" in the Create CSV file section.  Select the Output file to create.
    • Select Base Path and Run the script
    • This will generate an csv with all properties for the referenced objects : StefanLundin_3-1755767203412.png
  •  CSV to Properties to Mode:
    • Use the CSV generated from above.
      Adjust the values of the properties you do want to edit and remove properties you don't want to edit.
    • Select the CSV file
    • Select BasePath and Run the Script to set the defined properties on the referenced objects.
Important ⚠️  Back up your system before modifying objects !
The Script is available from SEAL Script, Standard Scripts
  • Script
Replies 0
