wrong sensor value Himoinsa generator
  • wrong sensor value Himoinsa generator
129
72
Posted: ‎2020-07-04 02:15 AM . Last Modified: ‎2024-04-05 03:53 AM
1442
there seems to be a problem with the value of several sensors, we are using modbus DDF CCLAN Module versión 5,
It is posible to check this:
  • Running Time (wrong value or number format ,none has worked more than 100 hours)
  • Succesful starts ,1 is the only value,
  • Pressure unit ( check unit,  bars or kPa, values or number format seems to be wrong)
  • Power per day and Power per month ( "0" is the only value)
Thanks in advance
Regards
(CID:126179564)
  • DDF
Posted: ‎2020-07-04 02:16 AM . Last Modified: ‎2024-04-05 03:52 AM
Hi Sergio,
What controller is fitted to the generator? I monitor Himoinsa gen sets but I tend to Poll the controller using the modbus DDF for a generic controller as below
Hope this helps!
Mike
(CID:126179808)
Replies 5
Posted: ‎2020-07-04 02:15 AM . Last Modified: ‎2024-04-05 03:52 AM
1442
Dear Sergio,
Judging from the screenshot below, this type of generator sets have successfully supported by DCE software:
Therefore, you can draw two conclusions: either you use an incorrect or not actual DDF-file (I do not think so 😀. Or, you need to create another Request modification for your DDF-file, so that DDF-team fixes the errors you found.
I am also personally interested in this, because soon, I will also need to connect a generator set of the same type to the infrastructure monitoring system with DCE-servers.
With respect.
(CID:126179613)
Hi, Thanks Spezialist and Mike
I going to request the DDF modification
regards
(CID:126181205)
Dear Sergio,
Thank you for following my advice 😀.
(CID:126181212)
Hi Sergio,
Hope this helps!
Mike
(CID:126179808)
Posted: ‎2020-07-04 02:16 AM . Last Modified: ‎2023-10-22 11:08 PM
