where could I find the document for detail report function?
  • EcoStruxure IT forum
  • where could I find the document for detail report function?
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:50 PM . Last Modified: ‎2024-04-08 12:50 AM
794
dear expert,
Where could I find the document for detail function for each report? For example, in capacity history report, there is one checkbox called 'ambient temperature', and we found that it has only 1 data each day and we don't know where DCO get it and how it was generated. Because we have more than 10 temperature sensors in one room and all data uploaded. And I don't know how to explain this to the customer. This situation also happens on some other reports.
Best Regards,
Ziqiang
(CID:118001107)
  • Data Center Operation
794
Hi Ziqiang,
Please see the following page, that contains full description of capacity history data:
Capacity history KPI description
Kind regards
(CID:118001126)
Replies 5
795
Hi Ziqiang,
Kind regards
(CID:118001126)
Hi Jef,
Thank you for the answer. The customer is asking, just for ambient temperature, could we give a description how this value be calculated because they have encountered some unreasonable values in the report ( see attached). They have some values which is lower than 0 degree in Celsius.
Ziqiang
(CID:118001540)
Posted: ‎2020-07-03 03:50 PM . Last Modified: ‎2024-04-08 12:49 AM
Hi Ziqiang,
The ambient temperature (sort of average temperature of the room) is based on the 2D cooling 'calculations'/algorithm. It is really just a rough estimation of the temperature of air that cannot be accounted for by rack exhausts or cooler supplies. However, the ambient temperature might be affected by manual settings such as rack & CRAC's cooling settings,
Kind regards
(CID:118003641)
Thanks Jef,
I have created a new thread for the ambient temperature question. The customer is not quite buy in this explain. They want some detail explanation. Could you help?
The following is on:
Thanks a lot,
Ziqiang
(CID:118622066)
Posted: ‎2020-07-03 03:50 PM . Last Modified: ‎2023-10-22 09:39 PM
