Posted: 2020-07-03 01:19 AM . Last Modified: 2024-04-09 12:38 AM
where can i see the modbus address in pme
(CID:105469213)
You can find the MODBUS address for a device in Management Console under Devices view. The address will follow the IP address of the Site. This is assuming the device was setup linked to a site using Ethergate at the gateway.
If the site is using Modbus Mastering and the device(s) is/are embedded with a meter's framework, then you would need to look at the Modbus Import module in that framework using Designer.
For devices that I write drivers for, I always include the register that has the address so it can be displayed on the template created to display in the HMI screen.
(CID:105469511)
(CID:105469511)
Posted: 2020-07-03 01:20 AM . Last Modified: 2023-10-31 11:43 PM
