where can I download the Easy UPS 3S MIB file
  • where can I download the Easy UPS 3S MIB file
129
72
Posted: ‎2020-07-05 11:54 PM . Last Modified: ‎2024-04-02 11:45 PM
2840
I would like to integrate our Easy UPS 3S into DCE. I have imported it but it appears as an SNMP Device. Is there a MIB file I can download so DCE understands what the unit is?
(CID:152080358)
Replies 4
Posted: ‎2020-07-05 11:55 PM . Last Modified: ‎2024-04-02 11:45 PM
2841
Dear Mario,
MIB file can not be uploaded in DCE software directly. I have attached the Easy UPS 3S SNMP card DDF file. Please check if you are able to see the device sensors after uploading the attached DDF file.
Please let me know if you still need MIB file. I can provide it to you.
ppc_upsmate.xml
(CID:152080398)
Thank you Balaraman. I assume you upload the file into DCE via the Device / SNMP Device Communication Settings section?
It recognises it as a UPS now.
Thank you for your help.
(CID:152570129)
Thanks for the update Mario! To import: Main menu->Device->SNMP Device Communication Settings->Device Definition Files->Add/Update Definitions
(CID:152570131)
Posted: ‎2020-07-05 11:55 PM . Last Modified: ‎2023-10-22 09:39 PM
