what is the best solution for integrating 2 DCE physical server(AP9465 expert) in a DCE VMACT ?
  • what is the best solution for integrating 2 DCE physical server(AP9465 expert) in a DCE VMACT ?
129
72
Posted: ‎2020-07-05 07:04 PM . Last Modified: ‎2024-04-03 02:46 AM
1075
(CID:143755305)
  • Portal
Hi Afsaneh,
there is no easy way to do this. If you import a backup into DCE and then import another, the second will not add to the first, it will overwrite it.
You can export discoveries from a DCE server which may make adding devices from a second server easier so if you’re looking to add devices from a second server to another already existing configuration, that would probably be the best option.
Steve.
(CID:143755370)
Posted: ‎2020-07-05 07:04 PM . Last Modified: ‎2023-10-22 09:39 PM
