what are the default login and username to connect to DCE ?
  • what are the default login and username to connect to DCE ?
129
72
Posted: ‎2020-07-04 07:40 PM . Last Modified: ‎2024-04-04 11:09 PM
2779
i want to monitor a M340 =SE= with DCE.
once i configured the network settings i access to the web page which require a 'login and password' to continue...
I have not configure it in the black box so where can i found them ? or are they generic ?
thank you
PS: je suis français 😀
(CID:132658804)
Posted: ‎2020-07-04 07:40 PM . Last Modified: ‎2024-04-04 11:08 PM
2779
Bonjour Johan,
Les logins et mots de passe par défaut sont apc/apc.
Cdt,
François
(CID:132658812)
Replies 8
2780
Bonjour Johan,
Cdt,
François
(CID:132658812)
bonjour françois,
après plusieurs recherches il s'agit en fait de USER/USER
Vu que mon appareil est marqué Télémécanique et non =SE=  il doit y avoir une différence
grand merci en tout cas
Johan
(CID:132660644)
2779
Hello Johan,
Aside from the default username and password (apc/apc), make sure that you are using TCP/IP to communicate with the DCE appliance.
This means that a computer on the same network as the DCE server should have the client software installed in order to access and configure the DCE device.
The simplest way to do it is to connect a laptop or a PC on the GB2 (private) port of the DCE and access the DCE device from there using by typing the IP address of the DCE server on a web browser.
I hope this helps.
Justine
(CID:132658882)
Posted: ‎2020-07-04 07:41 PM . Last Modified: ‎2024-04-04 11:08 PM
hello Justine,
the login password are USER/USER, certainly because of using a Telemecanique device and not a Schneider Electric device.
thanks for your response which can be useful futurly
Johan
(CID:132660650)
Dear FOUQUE JOHAN,
To make it clear: probably you asked for the default login/password for Modicon M340 device, not for DCE software?
And of course for Modicon M340 device it's USER/USER, and for DCE software it's apc/apc.
Did I understand you correctly?
With respect.
(CID:132660666)
hello,
i realise i used wrong IP adress.. i wanted to connect to DCE while using the M340 IP adress !
you all were right:  for DCE: apc/apc........... for M340: USER/USER
sorry everyone  and thanks a lot
(CID:132660723)
Ok, thanks for clarifying your question 😀.
(CID:132660733)
Posted: ‎2020-07-04 07:41 PM . Last Modified: ‎2023-10-22 09:38 PM
