Posted: 2020-07-05 08:35 PM . Last Modified: 2024-04-03 01:10 AM
I have DC version 8.2.12 and using couple vCenter integration. Each and every time when I start DCO desktop client I get this error message:
I go to External System Configuration into the same vCenter settings and click on Test button:
I have 7 other vCenter server in the system and crosschecked all settings and did not found any problem. Of course above mentioned vCenter is available and tested user credentials with a login which works fine.
What is the problem?
(CID:147194428)
Hi Mate,
Can I ask for server logs? to see if it contains useful info, thanks.
Kind regards
(CID:147195125)
Hi Jef,
Servers log and latest backup has been uploaded to appbox.
Thanks.
(CID:147196366)
Posted: 2020-07-05 08:35 PM . Last Modified: 2024-04-03 01:09 AM
Hi Mate,
Unfortunately I could not see error entries in the latest log entries, so it is not clear to me why you might be seeing the warning message. I will post you a direct email soon, thanks.
Kind regards
(CID:147202243)
Posted: 2020-07-05 08:35 PM . Last Modified: 2023-10-22 09:38 PM
