unable to connect power supplies to pdu in DCO
  • unable to connect power supplies to pdu in DCO
129
72
Posted: ‎2020-07-04 09:53 PM . Last Modified: ‎2024-04-04 03:31 AM
1265
I'm having an issue when trying to connect up the 2 PSU's in a Nexus 2248TP-E to 2 PDU's in the back of a rack.
The error i get is:
"One or more Power Distribution Units are not compatible with the selected server and are hidden"
The node is taken from a Genome in the standard list, not a manually created item.
Any ideas what this may be?
Cheers
N
(CID:133372863)
  • Data Center Operation
  • Genome
1265
Hi Neil
could you check the input voltage of your Nexus?
(CID:133372881)
1266
Hi Neil
(CID:133372881)
They were set to random figures.
The Genome must be incorrect that i've added in.
Cheers
Neil
(CID:133372888)
Posted: ‎2020-07-04 09:53 PM . Last Modified: ‎2023-10-22 09:37 PM
