struxureon gateway Certificate
  • EcoStruxure IT forum
  • struxureon gateway Certificate
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 04:38 PM . Last Modified: ‎2024-04-08 12:29 AM
793
is there a way for me to generate and issue a valid SSL cert for our StruxureOn gateway? using our own CA.
(CID:120129382)
  • Asset Advisor
Hi david.lim,
Since this procedure is quite similar and standardized, then as a very good example, you can use this instruction Replacing the SelfSigned Cert on PowerChute_Windows from APC k-base FA176886.
Below is my version of this instruction, but already applied to StruxureOn Gateway 1.0.3.40: Replacing the Self-Signed SSL Certificate in StruxureOn Gateway.pdf.
If you have questions, please ask.
(CID:120129668)
Hi david.lim,
Tell me, please, have you solved the problem or not?
With respect.
(CID:120131774)
Posted: ‎2020-07-03 04:39 PM . Last Modified: ‎2023-10-22 09:36 PM
