something about using DCO
  • something about using DCO
129
72
Posted: ‎2020-07-03 09:39 AM . Last Modified: ‎2024-04-08 03:28 AM
794
Hi:
I'm using DCO 8.0, Does DCO have the functions that can control devices like emergency power limit, shut off the power in Intel DCM and can I use webservices api to set it?
Best Regard and Happy New Year!
(CID:110012944)
  • Data Center Operation
Hi Ren,
I was wondering perhaps the "Server Access " could be the feature you were looking for. Server Access is an add-on module to DCO and it allows you to control servers from multiple vendors remotely (from DCO) whether they are turned on or off.  Following page contains detail description for this add-on module:
StruxureWare Data Center Operation: Server Access
Hope this helps,
Happy new year & best wishes
Kind regards
PS.  I think we had a known issue with the version 8.0, where the logs could grow unlimited over the time and might cause disc space problem. So it is highly recommended to upgrade the product (currently DCO 8.0.3).
(CID:110013329)
Hi Ren,
Hope this helps,
Kind regards
(CID:110013329)
Posted: ‎2020-07-03 09:39 AM . Last Modified: ‎2023-10-22 09:36 PM
