snmp device access
  • snmp device access
129
72
Posted: ‎2020-07-02 10:15 PM . Last Modified: ‎2024-04-09 01:31 AM
893
snmp device access
Hi All,
suppose to have a simple system composed by the following elements:
  • DCE
  • 1 device (for example a smart PDU)
  • an external BMS (third party)
Is it possible to implement the following architecture:
1) DCE talks to the PDU using snmp protocol
2) the BMS talks to the PDU using the snmp protocol as well
In other words the same snmp device should be addressed by 2 indipendent monitoring systems
Roberto
(CID:105460229)
Replies 4
Roberto,
This would be possible as long as the device is on the public LAN and both systems can communicate to it.  The SNMP settings on the device would also need to be setup to allow both systems to connect to it for polling.
Best Regards,
Cory
(CID:105460232)
Hi Roberto.
I think there will be no problem with such configuration. But as Cory says the PDU should be in the Public LAN. Also using DCE Web-services API is an option to pull data from DCE into third party software.
Best regards,
Roman
(CID:105460234)
Hi Roberto,
Another possible solution could be adding a Modbus TCP Output module (AP95MODBUS) to your DCE platform and having DCE pass monitoring data through to your BMS system.
Best Regards,
Kevin
(CID:105460304)
Posted: ‎2020-07-02 10:15 PM . Last Modified: ‎2023-10-31 11:35 PM
