Posted: 2020-07-03 01:01 PM . Last Modified: 2024-04-08 01:45 AM
(CID:111937629)
Hi Boyan,
The following command (currently in DCO 8.x) should restart the operations services:
sudo systemctl restart operations
furthermore, the following commands should stop and start the services:
sudo systemctl stop operations
sudo systemctl start operations
Kind regards
(CID:111937763)
Hi Boyan,
it should be noted that restarting services is considered an advanced topic. This means that if you do not know how to, you should definitely consider if.
On a related note, I am not certain how you got into situation where you needed to restart operations, but generally, the recommended action is to simply restart the server.
BR
Fredrik
(CID:111937905)
Posted: 2020-07-03 01:01 PM . Last Modified: 2023-10-22 09:35 PM
