Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
lost webmin details DCO 8.2.2
  • EcoStruxure IT forum
  • lost webmin details DCO 8.2.2
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:34 PM . Last Modified: ‎2024-04-03 05:03 AM
928
Hi I have a client running DCO 8.2.2 who has lost the Webmin password and more than likely there username as well i know we could recover them in earlier versions but that doesn't seem to work with Centos 7 has anyone got a workaround for this?? tried pressing e and editing the linux16 entry from "root ro" to "root rw init=/sysroot/bin/sh" then run  but still wont let me run the /etc/passwd cmd
I can log in using my user credentials but unable to sudo or run passwd as I've not got root access!
TIA
Mike
(CID:138810321)
  • Data Center Operation
Posted: ‎2020-07-05 04:35 PM . Last Modified: ‎2024-04-03 05:03 AM
928
Hi Mike,
Resetting user password  on the sever is described here:
Resetting user password on the DCO server
if you/customer do not recall the user name, after the step 4. (eg. 4. When you see Rescue Mount, press and type chroot /mnt/sysimage.) type:
less /etc/passwd
and look for the created user name - in the following screen shot my test user "apc" is highlighted:
then continue the password reset for this user (per instructions)...
Kind regards
(CID:138810350)
Replies 6
929
Hi Mike,
less /etc/passwd
Kind regards
(CID:138810350)
Hi Jef,
I have carried this out no problems thanks however now i cant access the web client or DCO Client i can ping the IP but when i try to log on it says connection refused!
is there anyway i can check services through the server?
Cheers,
Mike
(CID:138810988)
Posted: ‎2020-07-05 04:35 PM . Last Modified: ‎2024-04-03 05:02 AM
Hi Mike,
Perhaps (only guessing) the application is not ready yet.
Log in to server Webmin interface (https://:10000), StruxureWare DC Operation > Status and see if the application is running.
Kind regards
(CID:138811001)
It shows the following tried rebooting but no luck?
(CID:138811013)
Hi Mike,
I think in this case fast and reliable solution can be a clean installation of DCO and then restoring the latest "good" backup file.  Backup files are usually located in /data/backup folder.
PS: it is recommended to go for the latest version of DCO (currently 8.2.12)
Kind regards
(CID:138811341)
Posted: ‎2020-07-05 04:35 PM . Last Modified: ‎2023-10-22 04:41 AM
