how to simulate AC 220V in DCO?
  • how to simulate AC 220V in DCO?
129
72
Posted: ‎2020-07-02 06:48 PM . Last Modified: ‎2024-04-09 01:50 AM
734
Dear experts,
I'm simulating a server receiving power from AC 220V, but I received a "rackPDU is not powered" info, could you tell me how to implement that?
Here's the steps I did:
  1. put a PDU(InfraStruXure Modular IT Power Distribution Unit 277KW 400A 400V 72 Pole 300mm Rack) in the room
  2. in "properties -> power" option of the PDU, set "output voltage" to 220(110)/50"; and set "input voltage" to 380/50 (also, is it possible to set it to 220/50 one phase?)
    3. put a rack in the room (Netshelter Sx 42u 600mm Wide X 1070mm Deep Enclosure With Sides)  and put a RPDU(Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19) on it.
   4. in "properties->power dependencies" of RPDU,  set power supply.
     5. The information shows "rackPDU is not powered".
Please help.
Thanks with Best Regards,
Ziqiang
(CID:105458232)
  • Data Center Operation
HI!
For your RPDU's voltage you need to set 400 V output voltage on PDU. It is 3-phase system and in this field you choose L-L voltage.
(CID:105458240)
Posted: ‎2020-07-02 06:48 PM . Last Modified: ‎2023-10-31 11:07 PM
