how to link continuum with structureware for data centres
  • how to link continuum with structureware for data centres
129
72
Posted: ‎2020-07-03 04:08 AM . Last Modified: ‎2024-04-08 11:45 PM
1300
(CID:106209304)
  • Data Center Operation
Replies 9
Hi Richard, can you please elaborate the use case? There are many ways this can be accomplished, including Modbus TCP gateways or SNMP monitoring of controllers.
(CID:106209328)
The building have continuum BMS and they want to monitor the equipment in the Data Centre. this includes Symmetra PX250/500 UPS, in-row cooling units ACRC301H and Netbotz with sensors, also Schneider power meters in switch board. All this equipment is in DCO, DCE.
(CID:106209331)
Is Continuum and DCE/O on the same network or separate networks? Have you looked into DCE BMS integration Building Management Settings (System menu)
(CID:106209332)
Different network
(CID:106209334)
1300
Provided there is a way for Continuum to monitor DCE, is the plan to bridge the networks somehow? That's another challenge you might want to think about. I would recommend reaching out to professional services, this needs some real expert analysis.
(CID:108234599)
Posted: ‎2020-07-03 04:09 AM . Last Modified: ‎2024-04-08 11:44 PM
If they were on the same network, would this be more straightforward
(CID:108234602)
Hi Richard Vaughan, did you find a solution for your issue? Best, Stine
(CID:108234603)
Hi Richard Vaughan, I'm going to assume that this has been resolved. If that is not the case, please feel free to ask another question. Thanks, Stine
(CID:108234604)
Posted: ‎2020-07-03 04:09 AM . Last Modified: ‎2023-10-31 11:06 PM
