how to change position in height of electrical panel
  • how to change position in height of electrical panel
129
72
Ezequiel_Guffanti
Ezequiel_Guffanti
Cadet
Posted: ‎2024-01-31 08:22 AM
846
Good morning, then I ask for your help to know how to change the height of a board, it may be that I am using the wrong genome since I cannot find the physical configuration that does not allow me to determine the height at which it is installed. Thank you.
En mi idioma natural.
Buen día, luego solicito su ayuda para saber como cambiar la altura de un tablero, puede ser que este utilizando un genoma incorrecto ya que no encuentro en la configuración fisica no me permite determinar la altura en la cual se instala. Gracias.
  • DCIM Support
Captain
Posted: ‎2024-02-02 03:48 AM
Hello. As long as you have edit access to the device, you should be able to edit the devices physical properties in the properties view to set its dimensions like in the below screenshot.
If you want the device to have the changed dimensions each time you drag it out of the genome library, then the same physical settings are in the genome properties. Your user account would need the genome permission to be able to edit the genome in the genome list. You need edit access to the room to change the physical properties of an item placed in a room or rack.
Is this similar to what you're trying to do?
Regards
Greg Sterling
Captain
Regards
Greg Sterling
