how see what the uptime of DCE
  • how see what the uptime of DCE
129
72
Posted: ‎2020-07-03 05:49 PM . Last Modified: ‎2024-04-08 12:04 AM
1176
I would like to see what the uptime for our DCE system is.
(CID:122688952)
Replies 7
1176
Dear Albert,
You can view the DCE uptime on the Web client under Status.
(CID:122688963)
Just be aware that you must be logged into the Web interface via a user that has admin level privileges on your DCE server or they will get an error (Error 403: Forbidden)  when trying to access that page.
(CID:122689006)
Hi Albert,
if you have SNMP turned on in DCE, you can see the uptime with:
  • 1.3.6.1.2.1.1.3 - sysUpTime
Otherwise, you should be able to see it in the web UI under status.
Steve.
(CID:122688970)
Hi a.castaneda,
If you connect a DCE-server to the StruxureOn digital service, then uptime can be easily seen through the StruxureOn app as in the screenshot:
With respect.
(CID:122689189)
We are using Struxureware DCE 7.2.7. We are not using StruxureOn.  I do not see an option for server status.
Albert
(CID:122689311)
a.castaneda, it is necessary to search not "Server Status" in web GUI, but simply "Status" as in the screenshot Balaraman Jagadeesan.
With best regards.
(CID:122689314)
Posted: ‎2020-07-03 05:49 PM . Last Modified: ‎2023-10-22 04:37 AM
