Posted: 2021-03-17 01:57 PM
exchange rate import
How to get exchange rate with web service in DCE?
I want to write the central bank turkey exchange rate in DCE
Data Center Expert
- Tags:
- english
Posted: 2021-03-22 11:49 AM
Hi Huseyin,
Here's the DCE web services API section of the help center. If you can't find your answer there, I'd suggest contacting your local technical support for assistance.
https://dcimsupport.ecostruxureit.com/hc/en-us/sections/360006467394-DCE-web-services-API
Best regards,
Jackie
- Tags:
- english
Posted: 2021-03-23 12:33 AM
this solution for get data from DCE, can you have any example for getting data to DCE
- Tags:
- english
Posted: 2021-03-23 05:13 AM
DCE does not support importing data via API, ETL, or any other means. Instead, it can poll devices via snmp or modbus. If you have another device/software that can take in this data point via an API and expose it as an snmp or modbus point, then it can be discovered by DCE and added in.
Alternatively, you could always create a custom property and put in a static value manually which could be used for reports.
Can you elaborate a little more on why you wanted this data point in DCE? I assume it would be related to calculating energy cost?
As an alternative, you could use another dashboarding/reporting tool that can use both DCE's API and this value via an API and combine them that way.
- Tags:
- english
Posted: 2021-03-23 05:39 AM
Hi Huseyin,
Can I ask for a bigger picture of what you're trying to solve here? Bringing non-sensor data into the DCE is very unusual and not how the platform is designed - perhaps if we better understand the problem, we can better suggest a direction.
- Tags:
- english
Posted: 2021-03-23 12:32 PM
Hi I tried export data but I get this error in ewsclient but I connected successfully with browser,
- Tags:
- english
