Posted: 2020-07-04 10:08 PM . Last Modified: 2024-04-04 03:26 AM
hello
1.I do not see the names of the equipment in the rack,
2.And does not see the rows in the rack
help please
(CID:133374946)
Hi Roni,
Could you please add some screen captures illustrating the issues + the version of DCO? thanks.
Kind regards
(CID:133375111)
the verison8.2.2
(CID:133375835)
Hi Roni,
Many thanks for the info & screen capture.
The equipment in your screen capture are rear mounted, click on the rack toggle sign (illustrated) to switch the rack view to Rear (from Front):
Then you should see the rear mounted equipment (including device names).
Kind regards
(CID:133375913)
hii,
I don't see the numbers of unit In the rack
(CID:134022866)
Hi Roni,
Which Genome Library device are you using to model your rack? (customized ? if yes, how?)
If you re-model and/or use another rack, do you see the same issue?
Kind regards
(CID:134022871)
Posted: 2020-07-04 10:09 PM . Last Modified: 2024-04-04 03:26 AM
HII '
id you see to this picture I don't have a numbers of unit..
10
9
8
(CID:134032438)
Hello Roni.
You experience this behavior with all racks or a few of them?
Also, which licenses do you have installed?
I'm able to reproduce a rack view without U numbers when I initially view a rack after a room has been opened, but the moment I zoom closer to the rack the U-numbers appear on the front and rear sides.
GregS
(CID:134032436)
Posted: 2020-07-04 10:09 PM . Last Modified: 2023-10-22 04:32 AM
