Posted: 2020-07-05 08:02 PM . Last Modified: 2024-04-03 01:21 AM
We are currently using DCO 8.0.3 in cluster mode of Active & Active mode; does dco 8.3 latest version support cluster in active and active mode
(CID:144869554)
Posted: 2020-07-05 08:03 PM . Last Modified: 2024-04-03 01:21 AM
Hi Rumesh,
Due to the setup complexity and server performance issues, cluster option is discontinued (many versions ago), so it is not supported in 8.3.
I would recommend to move the product to Standalone+DR node.
Since you already have two servers and High Availability license, you would not have additional cost to move to the product to the recommended setup. High Availability license can also be used for Disaster Recovery (DR) setup.
Backup from your current cluster setup can be restored on Standalone and/or Standalone+DR.
Kind regards
(CID:145424391)
Posted: 2020-07-05 08:03 PM . Last Modified: 2023-10-22 04:32 AM
