dco rest api _ Create a new asset
  • dco rest api _ Create a new asset
127
65
Posted: ‎2020-07-03 03:01 PM . Last Modified: ‎2024-04-08 01:07 AM
819
I'm trying  to create a new asset inside an asset with an id specified.
I'm using this api: "/assets/{asset-id}/children
In example I want to create an asset similar to this, in the same parent asset:
[ { "id": "c2e5b43a-d826-4346-8c5c-ee793df3cfe3", "type": "storage", "location": "Global/Magazzino ED.9", "parentId": "9a334b63-fe6e-41af-b4a4-bf25e624f324", "parentName": "Global", "parentType": "location", "roomId": null, "roomName": "", "roomType": "", "cageName": "", "rackName": "", "barcode": "", "description": "", "name": "Magazzino ED.9", "manufacturer": "", "modelName": "", "partNumber": "", "serialNumber": "", "customPropertyKeys": "", "customPropertyValues": "", "luceneSearchScore": 0.028692061 }, { "id": "ddd4bbc6-97fb-43bc-aa50-aac2dd05486a", "type": "server", "location": "Global/Magazzino ED.9/PowerEdge R730", "parentId": "c2e5b43a-d826-4346-8c5c-ee793df3cfe3", "parentName": "Magazzino ED.9", "parentType": "storage", "roomId": "c2e5b43a-d826-4346-8c5c-ee793df3cfe3", "roomName": "Magazzino ED.9", "roomType": "storage", "cageName": "", "rackName": "", "barcode": "", "description": "Dell PowerEdge R730", "name": "PowerEdge R730", "manufacturer": "Dell", "modelName": "PowerEdge R730", "partNumber": "", "serialNumber": "123456789", "customPropertyKeys": "Aquired Admin", "customPropertyValues": "06/03/17 Server", "luceneSearchScore": 0.011737661 } ]
So, in /assets/{asset-id}/children I've as a parameter assetCreationVO and I can specify these paramenters:
yCoordinate , bayPositionNumber,rackMountPosition , genomeId,uPosition,bayPosition.
How can I specify custom properties as "name", manufacturer during asset creation?
thanks in advance
luca
(CID:116918715)
  • Data Center Operation
Replies 6
819
I've tried with this AssetVo request:
"yCoordinate": 0,
"bayPositionNumber": 0,
"rackMountPosition": "TOP_MOUNTED",
"genomeId": "030050000010",
"uPosition": 0,
"bayPosition": "UPPER_SLOT",
"xCoordinate": 0
but I receive:
400
Can not construct instance of java.util.UUID from String value '030050000010': not a valid textual representation, problem: UUID has to be represented by the standard 36-char representation at [Source: io.undertow.servlet.spec.ServletInputStreamImpl@6a54a205; line: 4, column: 37] (through reference chain: com.apc.webservice.api.assets.model.AssetCreationVO["genomeId"])
Whare can I find a valid genomeId valid textual representation?
thanks
(CID:116919610)
I've also tried with a valid genomeID (36 char), but also in this case I've a failure response:
{ "code": 100108, "message": "Adding assets to this asset is not supported", "details": "c2e5b43a-d826-4346-8c5c-ee793df3cfe3" }
It  seems that  I can't add an asset to this parent.
could you give me any hints?
thanks
luca
(CID:116923282)
I've tried again with same result.
genomeID is a valid genome.
I'm trying to create an asset into an asset that is a location:
"type": "location",
"parentId": null,
"children": null,
"navigationPath": null,
"customProperties": null,
"accessType": "EDIT",
"name": "Global",
"id": "9a334b63-fe6e-41af-b4a4-bf25e624f324"
thanks
(CID:118003996)
Hi lucama,
thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:116923284)
Posted: ‎2020-07-03 03:01 PM . Last Modified: ‎2024-04-08 01:06 AM
some one could give me any hint?
thanks
(CID:119637966)
Posted: ‎2020-07-03 03:01 PM . Last Modified: ‎2023-10-22 04:30 AM
