Posted: 2020-07-03 09:42 PM . Last Modified: 2024-04-07 11:40 PM
Is the DCE 7.4.3 client compatible with windows 10? I recently upgraded my os to windows 10, when I went to reinstall the DCE client, the installation failed with the following error.
(CID:123347706)
Hi jmeza,
Yes, of course, DCE-client is fully compatible with MS Windows 10 (x86 and x64).
At me, for example, the DCE-client is normally installed on MS Windows 10 Home x64.
Please specify the full name of the installation file that you are trying to install in your MS Windows 10?
With respect.
(CID:123347764)
Hi jmeza,
Have you solved this problem or not?
With respect.
(CID:123348038)
Hi jmeza,
I'm assuming your issue was solved. If not, please ask another question.
Stine
(CID:128747691)
Posted: 2020-07-03 09:42 PM . Last Modified: 2023-10-22 04:29 AM
