Posted: 2020-07-04 11:33 PM . Last Modified: 2024-04-04 02:30 AM
Hi all,
Where can i find DDF for com´x 210 so i can scan for it i DCE?
https://www.schneider-electric.com/en/product/EBX210
BR//
Samir
(CID:134031389)
Dear Samir Sörensen,
I would first try downloading the Modbus DDF-file powerlogic_210.xml from the Device Support resource, that is, for device PowerLogic PM210:
Then you will need to import this DDF-file into DCE software and see if it will work properly.
If not, then on the above specified resource, you can immediately make a new device support request and after a while DDF-developers will contact you to specify the details and the time of completion of work.
I hope this helps you.
With respect.
(CID:134031474)
Tanx for the answer but it didn´t work. I need a new DDF.
BR,
//Samir
(CID:134680186)
Posted: 2020-07-04 11:34 PM . Last Modified: 2024-04-04 02:30 AM
Ok, I hope you created the correct device request on the above resource? There is also an explanatory video.
If you have more questions, please ask.
With respect.
(CID:134680220)
Tell us, please, did you solve your question or not?
With respect.
(CID:134680009)
Posted: 2020-07-04 11:34 PM . Last Modified: 2023-10-22 04:27 AM
