colo user equipment library
  • EcoStruxure IT forum
  • colo user equipment library
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 02:50 AM . Last Modified: ‎2024-04-05 03:42 AM
903
Some Colo users are unable to see equipment in the Equipment Library although it has been added to the Genomes.
Logged in as a DCO user I can see it in the Equipment Library.
(CID:126880193)
  • Data Center Operation
Replies 4
903
The difference may be if you're logging in as a tenant user vs a DCO user. DCO users should see the customized genome catalog which is visible in the DCO desktop client.
Tenant users see the master library shipped with DCO. They do not see the customized library which is maintained by the colo provider.
Regards
Greg Sterling
(CID:126880441)
Hi Greg,
This is not acceptable.
A few examples:
  • If the tenant does not lower the adjusted nameplate (by default we put it at 50% of the manufacturer's nameplate in the genomes) -> oversizing !!!
  • When an equipment is not in the genome library -> request to add it -> after weeks/months an updated genome library is uploaded -> tenant can add equipment
  • A tenant can adjust the power, physical & properties of an equipment (coming from the genome library) after adding it to one of his racks. But can't copy this device. So he will have to do it for every device.
I see this as a bug.
(CID:126880992)
Hi Eduard,
I agree with Greg, that per design tenant users can see the Genome Library, and may not have access to the customized Genomes which is owned and maintained by the colo provider. However you are most welcome to post a feature request here: Feature requests
Kind regards
(CID:126881195)
Posted: ‎2020-07-04 02:50 AM . Last Modified: ‎2023-10-22 04:27 AM
