can the DCE/DCO/Struxureware Portal be CAC enabled?
  • EcoStruxure IT forum
  • can the DCE/DCO/Struxureware Portal be CAC enabled?
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 02:00 PM . Last Modified: ‎2024-04-05 02:46 AM
814
Can the DCE, DCO, and Struxureware Portal be CAC enabled?
(CID:128753879)
  • Data Center Operation
  • Portal
Posted: ‎2020-07-04 02:01 PM . Last Modified: ‎2024-04-05 02:46 AM
814
We do not currently offer this feature.
(CID:128753884)
Replies 4
815
(CID:128753884)
Thanks for the quick response!
(CID:128753887)
You indicated that the DCE/DCO/Struxureware Portal could not be CAC enabled.  I passed this information along during one of our meetings with our PKE team.  The PKE team said that there is some Enterprise Management Suite software that can be CAC/two factor enabled.  I'm not sure they have the correct information so I wanted to follow up with you?  Is there some "Enterprise Management Software" that allows two factor authentication for the DCE/DCO/Struxureware Portal?  Also, wanted to verify that there was no CAC/two factor authentication for the netbotz/PDUs.
(CID:129409293)
Posted: ‎2020-07-04 02:01 PM . Last Modified: ‎2023-10-22 04:26 AM
