Will DCO 8.1 install in the following hardware - DL360 Gen 10
  • Will DCO 8.1 install in the following hardware - DL360 Gen 10
126
65
Posted: ‎2020-07-04 12:01 AM . Last Modified: ‎2024-04-05 04:43 AM
996
Will DCO 8.1 install in the following hardware:
HPE ProLiant DL360 Gen10 4114 85W 1P 16G-2R P408i-a 8SFF Base Server
  • ·         4114 (10-Core, 2.2 GHz, 85W)
  • ·         32 GB RDIMM 2R 2666 MT/s  (2x 16 GB)
  • ·         2 x HPE 600GB SAS 12G Enterprise 10K SFF (2.5in) SC 3yr Wty Digitally Signed Firmware HDD ( or HPE 400GB SAS 12G Mixed Use SFF (2.5in) SC 3yr Wty Digitally Signed Firmware SSD) configured as RAID 1
(CID:125213394)
  • Data Center Operation
997
Hi John MacDonald,
According to the information on page System requirements, we have:
Recommended StruxureWare Data Center Operation server configuration Server requirement guidelines (minimum)
  • CPU: 4 cores minimum. We recommend 8 cores
  • Memory: 16 GB RAM (absolute minimum requirement)
  • 100 GB storage, speed minimum 170 MB/s
  • Cluster network: 1 Gbps connection between nodes
  • Disaster recovery network: 10 Mbps with low latency <100 ms
If your'e installing DCO on an existing server, note that DCO claims almost all memory (JVM about 8 GB and Postgres about 6 GB alone). Therefore, you may experience issues if you have other applications running on the server, such as surveillance and monitoring agents.
Server requirement guidelines for 10,000 racks across 200 rooms with 30 concurrent users
  • 8 CPU cores
  • 32 GB RAM
  • 1 Gbps network connection between cluster nodes
Server requirement guidelines for 20,000 racks across 400 rooms with 30 concurrent users
  • 16 CPU cores
  • 64 GB RAM
Thus, your physical server is no problem with DCO configuration up to 10,000 racks (which probably exceeds your real needs).
With respect.
(CID:125213407)
Replies 5
998
Hi John MacDonald,
  • 8 CPU cores
  • 32 GB RAM
  • 16 CPU cores
  • 64 GB RAM
With respect.
(CID:125213407)
Thanks for your comments but I was asking due to the RAID controller - please confirm DCO 8.1 will install on this device, thanks!
(CID:125213425)
Hi John MacDonald,
In your question, you did not ask about the RAID controller 😀.
And yet, according to the official specification for the HPE Smart Array P408i-a Controller on page HPE Smart Array P408i-a Controller - Overview, its guaranteed support for CentOS Linux (see also file HPE Smart Array Operating System Support Matrix). Let me remind you that DCO-8.1 is based on CentOS-7 Linux.
With respect.
(CID:126158687)
Posted: ‎2020-07-04 12:02 AM . Last Modified: ‎2024-04-05 04:43 AM
Hi John MacDonald,
Have you solved your problem or not?
With respect.
(CID:126159012)
Posted: ‎2020-07-04 12:02 AM . Last Modified: ‎2023-10-22 04:22 AM
