Why is there no SNMPv2 Counter64 support in DCE?
  • Why is there no SNMPv2 Counter64 support in DCE?
129
72
OmerHanay
Ensign OmerHanay
Ensign
Posted: ‎2025-03-13 01:44 AM
880
I need to read Counter64 values using SNMPv2, but in the web interface, only SNMPv1 and SNMPv3 are available. Even though SNMPv2 is supported, Counter64 values cannot be read.
The product I want to integrate broadcasts certain SNMPv2 data points using Counter64. How can I resolve this issue?
MIB BROWSER Walk;
1.3.6.1.4.1.35483.1.1.1.3.1.1.3.290, OctetString , Modbus-Temp-Hum.Temperature3
1.3.6.1.4.1.35483.1.1.1.3.1.1.3.291, OctetString , Modbus-Temp-Hum.Humidity3
1.3.6.1.4.1.35483.1.1.1.3.1.1.3.292, OctetString , Modbus-Temp-Hum.Temperature4
1.3.6.1.4.1.35483.1.1.1.3.1.1.3.293, OctetString , Modbus-Temp-Hum.Humidity4
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.0, Counter64 , 2311
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.1, Counter64 , 0
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.2, Counter64 , 5000
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.3, Counter64 , 1000
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.4, Counter64 , 0
1.3.6.1.4.1.35483.1.1.1.3.1.1.4.5, Counter64 , 0
DCE Web Snmp Walk;
OmerHanay
Ensign OmerHanay
Ensign
Posted: ‎2025-03-22 02:41 PM
In response to APC_Steve
Yes the problem was solved when we used SNMPv3. Thank you
Captain
Posted: ‎2025-03-14 04:29 AM
Hi @OmerHanay ,
I see that SNMPv1 does not support the counter64 data type but in reading up on SNMPv3, it should support the counter64. Was your walk only in SNMPV1 or did you try SNMPv3 as well.
I don't have anything that I know for a fact outputs a counter64 type so I can not test but I would assume that since DCE supports the same data and same DDF files, that the data types supported must remain the same between the 2 supported versions for compatibility reasons. I can try to speak with engineering on this but what I can tell you is that there is no configuration option that can be adjusted in DCE to allow for any data type that it is not already supporting.
Tanks,
Steve
Captain
Posted: ‎2025-03-14 04:36 AM
833
P.S.
Your above walk WAS in SNMPv3, correct?
OmerHanay
Ensign OmerHanay
Ensign
