Which ports are used in StruxureWare Data Center Expert?
  • Which ports are used in StruxureWare Data Center Expert?
126
65
Posted: ‎2020-07-02 07:06 AM . Last Modified: ‎2024-04-10 01:47 AM
2947
Which ports are used for communication with DCE?
(CID:83656842)
The following outlines ports used and their application on any StruxureWare Data Center Expert server:
Note: Ports or Protocols preceded by * can be changed from their default port number.
Incoming ports
Port 80 (TCP/UDP) - *HTTP Communication from NetBotz Appliances / *DCE Console/Web API and 3rd party integrations.
*Port 443 (TCP) - HTTPS Communication from NetBotz Appliances / DCE Console
*Port 161(UDP), 162 (TCP/UDP)- SNMP Communication from SNMP Agent
*Port 502 (TCP/UDP)- Modbus TCP Communication from Modbus Device/Gateway Outgoing:
Outgoing ports
Port 80 (TCP/UDP)- *HTTP Communication to NetBotz Appliances / *DCE Console / HTTP Post to Web Server/Web API and 3rd party integrations.
*Port 443 (TCP) - HTTPS Communication to NetBotz Appliances / DCE Console
*Port 161 (UDP), 162(TCP/UDP) - SNMP Communication to SNMP Agent
*Port 25 (TCP)- SMTP Communication to Email Server
Port 21 (TCP)- FTP Communication to FTP Server
Port 123 (UDP)- NTP Communication to NTP Server
Port 139 (TCP/UDP)- SMB Communication to NAS / SAN
Port 53 (TCP/UDP)- DNS Communication to DNS Server
Port 111 (TCP)- NFS Mount
Port 2049 (UDP)- NFS Communication to NAS / SAN
Port 6000 (TCP)- APC Proprietary Communications protocol for use with AP76xx outlet strips and gen1 PDU on private lan.
Port 445 (TCP)- CIFS Communication to NAS / SAN
Port 502 (TCP/UDP)- Modbus TCP output to Building Management System
*Port 389(TCP/UDP)- Active Directory/LDAP
(CID:83656845)
Posted: ‎2020-07-02 07:06 AM . Last Modified: ‎2023-10-31 11:44 PM
